What Weight or Type of Gear Oil To Use ???
Fatback
05-09-2001 03:31:18
Removed the "Homemade" wide front end on the "C" and installed the orignal narrow front.
Discovered that the steering box is dry.
What weight or type of gear oil should I install?
gene b
05-10-2001 04:22:19
 Re: What Weight or Type of Gear Oil To Use ??? in reply to Fatback, 05-09-2001 03:31:18
it wont take long to find out if the seal is bad its not to hard to replace it would be hard to keep the top thrust bearing well lubed with grease you will find out how much easier it steers with it full of gear oil
The Red
05-09-2001 05:01:27
Try 90W. However if the seal is shot and the 90W leaks out, you might have to pack it in grease.
