ActionYobbo
I had rebuilt the brakes 2 years ago and have had no trouble with the brakes since the rebuild until last weekend when the I went to use the tractor the right side wheel was locked up. I quickly figured out it was the brakes and loosend the bolts holding the brakes on and the tractor was able to move. This weekend I took the brakes off expecting to find broken parts but everything looks good with new balls and springs and pads. Everything was dry and the pads look good.There was no extra pull on the adjuster or pedal and the linkage had a small amount off free travel.
When I built the brakes they had extra clearance because of wear on the metal parts but now there is +30thu outside the housing.
The tractor had sat for 3 months since I last drove it. I park it with out the brakes on.
