I took it off, took it apart, cleeaned it again, made sure the float and needle worked flawlesly, sprayed oil on where the float swings, carefully put it back together. Waited a day for the oil to get into wherever it might have to. Started it yesterday. No difference. Im going to, tonight, take it off and apart again. Im going to leave the gas line hooked up, and turn the gas on, and move the float up and down. The only thing I can figure at this point is that the float has a hole in it, tho I never noticed any weight in it while moving it up and down to see if the needle worked. Thanks for all and any of your replys
