lester350u
New User
I went thru distributor, cleaned polished lubed and reinstalled no change. I'm not seeing any change from TDC on the timing light at 900 RPM to 2200 RPM. I even took a donor distributor went thru it and installed my electronic ignition into it and still no change.is there any thing else that could cause it not to advance or retard whatever it is supposed to be doing I'm really confused. I'm pretty sure I need
to rebuild carb as I can only get it to run smooth at 900 rpm. Anything lower than that it runs bad and try's to die. Not sure what is going on?
