Just a little story about my BN that I was having a problem with loss of power to the point it would quit running for a few seconds then pick up and run again.
This happened a couple times last year and I found the problem to be some small bits of tank sealer that had fallen off and were getting caught in the inlet to the fuel strainer/shut off valve. At that time I managed to pick out the few pieces that appeared to be some small drips that did not adhere to the take when I used the sealer. It ran great the rest of last year and then last week it did it again.
The fuel strainer has a cast in "standpipe" about 7/16 od with a 1/4 inch hole in the center. This time I was able to see with a flash light a nice round flake of this sealer maybe 3/8 round just managing to seal off the top of this "standpipe". As there is no perfect way to be sure I would ever be sure there were no more of these little flecks hidden in the tank I decided to try something to make it impossible for them to cause a problem in the future.
What I came up with is a screen to cover the top of the "standpipe" so there is no nice flat surface for anything to create a seal on top of it. What I used was a piece of screen from a water hose washer with a screen made into it. formed it to a nice fit on the "standpipe" then epoxied it in place. See picture below:
