Tom in OR
- Location
- Tygh Valley, Oregon
Everything is apart, clean and ready to put back together. Replaced transmission front main shaft and counter shaft seals, throw out bearing, clutch disk, etc. on '50 M. Noticed that there is some slop in the transmission driving shaft ball bearings. After studying parts book exploded views, it appears to be easy to replace the two ball bearings on the short driving shaft.
Question is, however, with a pilot bearing on the nose of the main shaft that inserts into the rear of the driving shaft, can this pilot bearing be re-inserted into the rear of the driving shaft, blind and by feel, without removal of transmission top cover? It seems that if the main shaft would move out of alignment, even slightly, it might be pretty much impossible to reinsert that pilot bearing into the rear of the driving shaft.
Has anyone accomplished this maneuver or had any 'positive' experience doing this? Project is on temporary hold!
Thanks for any advice you may have!!
