I just got done rebuilding the hydraulic control box due to the hydraulics constantly jumping down and up. Found a bent control valve which had one of the actuators stuck as well. Installed a used one and everything moves freely. When I was installing the rockshaft the pins that go through the connecting rod have no space between them and are hitting one another.
I looked back at my pictures i took before i took it apart and noticed that the problem must have been there before because whoever had it apart last slid the pin to the left and only put one cotter pin in the connecting rod pin instead of 2 to allow some space. I'm thinking this may have been the reason why the control valve on the left hand side was bent.
There is a gap between the bearing and the Left hand arm. I have no idea as to why there isn't enough space between the two arms. This really has me stumped.
