I'm working on a 300 that was not a running machine when I got it and I currently have the engine out. With the transmission out of gear, and when I try to turn the center input shaft to the transmission in High range I can only turn it one direction (normal rotation direction). If I push the clutch in it will go both ways and it will also go both ways with the T/A engaged. I would have thought it should work both directions at any time. I'm guessing applying the clutch releases the T/A clutch and it is being prevented from spinning backwards due to the one way bearing in the T/A?
This is my first T/A tractor, I have a basic understanding of the system. Just wondering if this was normal. I'm using the clutch disc to spin it so I can only twist it backwards so much by hand. If this is normal wondering what would happen if the engine happened to spin over backwards.
