Ok I give up!! I have spent about 30 minutes on the IH site and cannot find the inner bearing for the rear axle.
First refresh my memory, if you remove the IPTO from a Farmall 300, can you see the rear axle bearings without taking the bull gear off?
Second I believe the bearing number is an ST 213 or ST 218. Where has anyone found the best bearing for this application? I know many bearings have less rollers since they are made overseas.
