jerseysierra
I am in the process of replacing the TA in a 560. I am having difficulty removing the TA clutch shaft. The throwout bearing carrier does not want to budge on the shaft at all. I had a donor TA section that had the exact same problem and I had to cut the shaft. I assumed that carrier was just rusted to the shaft and wasn't too concerned. But now the recipient tractor which isn't rusted is having the exact same problem. Yes, I removed the locking screw on top of the shaft. Am I missing something else obvious??? I haven't tried applying heat yet, just penetrating fluid.
