(quoted from post at 11:38:26 02/28/21) I have an A tractor that I have converted to 12v. The coil I got from the IH dealer said it was for 12V with external resistor. When I am cranking the tractor I have no spark from the coil, if it is still rolling over when I release the starter it will fire and start. If I attach a jumper wire across the ballast resistor it will send a spark while cranking and continue to run when the wire is removed. Is my coil possibly designed for 12v input? It has 2.4 ohms across the primary when cold. The resistor I'm using has 1.3 ohms resistance.
Unless you have a $$$$ meter it may not be reading low Ohms accurately.
Your reading of 2.4 Ohms is in between the 1.6 Ohms or so of the typical 6 Volt coil and the 3 - 3.5 Ohms of a typical 12 Volt coil, impossible to say if the coil is "odd" or the meter reading is not accurate.
If you have an Ammeter capable of reading in the 5 Amps range that is a more accurate way to determine what's going on.
With the battery fully charged and the breaker points "closed", connect the meter to read coil primary current, then switch the ignition "ON" and read the current.
Typically, you want to "see" between 3 and 4 Amps.
If the primary resistor's value is too high and current is at the lower end of that range or below spark will be weak.
On the other hand, primary current approaching or exceeding 4 Amps can cause excessive coil heating and shortened breaker point life.
A couple of other "ideas", check battery voltage while cranking, a 12 Volt battery with a weak cell would still crank that little engine well, but with weak spark voltage, I've had exactly that happen.
Check for full battery voltage at the switch side of the resistor, a "weak" ignition switch or poor connection in the primary circuit could cause voltage drop and weak spark. The points need to be closed while checking this to "load" the primary circuit.
Also, poor resistance-type sparkplug and coil wires, or a missing carbon "brush' in the distributor cap or a mismatch of cap and rotor could be causing a weak spark.
Just some things to check out!
