scubasteve
Hello again, I posted a message the other day about my narrow front end Farmall M and I have another issue with my Hub assembly. Today I was finishing cleaning the hub assembly and I grabbed the inside race and pulled it out with my fingers. I was alarmed so I went ahead and used a Micrometer to check the dimensions of the Race and the Hub Assembly. The O.D. of my Race measured to 3.152 and when I measured the inside of the hub assembly where the race would seat it measured 3.162. That is a difference of .010, what stops this race from turning when the wheel is turning? I have always had to press my races into the wheel hubs this thing is loose. what should I do? I know it is the right bearing and race. Do I need to buy a wheel Hub or can I shim it out?
