steering bolster (?) stripped splines
rogan12
New User
I HAVE AN IH 300 UTILITY. THE SPLINES FOR THE STEERING WHEEL ARE ALL ROUNDED OFF. I PURCHASED A NEW STEERING WHEEL. BUT THAT DONT FIX THE STEERING BOLSTER SPLINES. ANYBODY HAVE A FIX FOR THIS ?? I'VE LOOKED INTO BUYING A NEW ONE BUT THE ONES THAT IVE COME UP WITH DONT LOOK LIKE THEY HAVE THE SPLINES. IM CONFUSED
(quoted from post at 11:32:40 02/23/21) take a 6 inch triangular file and spend an hour and a half re filing the splines. Jim
THANKS JIM, THATS WHAT I FIGURED. JUST NOT WHAT I WAS LOOKING FORWARD TO. HAVE FILE WILL FILE I GUESS
(quoted from post at 09:58:52 02/23/21) I HAVE AN IH 300 UTILITY. THE SPLINES FOR THE STEERING WHEEL ARE ALL ROUNDED OFF. I PURCHASED A NEW STEERING WHEEL. BUT THAT DONT FIX THE STEERING BOLSTER SPLINES. ANYBODY HAVE A FIX FOR THIS ?? I'VE LOOKED INTO BUYING A NEW ONE BUT THE ONES THAT IVE COME UP WITH DONT LOOK LIKE THEY HAVE THE SPLINES. IM CONFUSED
Or if its a " work " tractor, tack weld it on like i did .
(quoted from post at 12:10:43 02/23/21)
IT IS A WORK TRACTOR, AND THATS A GREAT OPTION, THANKS FOR THE SUGGESTION
if you have splines you must have power steering manual steering had key shaft you will have to ps shaft or repair as other post
Welding it on makes itOk for a little while, then it junks the entire system as the sahft (no longer available) is not easily removed. Jim
The PS steering wheel is massively covered with plastic and a Power Steering decorative center covering the nut. Heat will make a mess of it. Jim
