Super C Touch control linkage- need help
Would someone be kind enough to post a picture of the touch control linkage. Specifically the right side of the tractor where the linkage passes behind the hydraulic lines? Not sure of the orientation of the linkage as it is factory bent a certain way. Unless I have the two sides mixed up? This is for a 53 super c. Thanks in advance!
I think that hyd. hose on the outside is supposed to be behind the valve. That's the way it was thirty years ago, have
had the valve off since but forgot to change it. Also keep forgetting to find a new boot for the valve.
(quoted from post at 15:18:09 02/22/21) I think that hyd. hose on the outside is supposed to be behind the valve. That's the way it was thirty years ago, have
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79280.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79281.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79282.jpg"
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79285.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79286.jpg">
Thanks for the pictures they really helped. It appears that I have the straight one on the wrong side. From your pics the bent one is on the left side. Ill have to swap it out. I was wondering why it wouldnt go on for me. I guess I shouldve labeled them when I took them off. Thank you.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79287.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto79288.jpg">
