Company Logo Shop Now
Re: How important is it to use "hy-tran"
AlinMO
02-22-2021 09:07:00
Several states ban 303 oil. You will want to check product to see what specs it meets. See below quote from Missouri:
MDA Removes 303 Tractor Hydraulic Fluids From Sale, 303 Manufacturers Recall Product
Missouri retailers of tractor hydraulic fluid (303) have been notified by the Department that these products are misbranded because they fail to meet any current tractor manufacturer s specifications. The John Deere (JD) 303 designation is 57 years old and has been obsolete for 43 years. In addition, there are no specifications available for 303 Tractor Hydraulic Fluids and, as such, products making only "303" claims cannot be tested to assure compliance with any known specifications. This action is being taken to protect tractor owners from equipment damage.
Over the summer the Department sampled 14 different 303 fluids, many claiming to work in almost every tractor. All 14 of these 303 fluids failed to meet current specifications and were found to be underperforming to the point that damage was likely to result from use.
Companies have been given the opportunity to revise their claims on the container to clearly identify the appropriate use of the product therein. The Department is working with manufacturers, distributors and retailers to ensure a low cost product with accurate labeling is available in the State of Missouri.
In the end, this action was taken to protect you and every other tractor owner in Missouri from damage to equipment. We are continuing to work with companies to revise their product claims or provide a higher quality product that meets a verifiable OEM tractor specification.
Notice to retailers with 303 products
Please contact your oil supplier to return any mislabeled 303 products for full credit. If you experience a problem with your return, please contact Weights, Measures and Consumer Protection Division Director Ron Hayes at (573) 751-4316.
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
