Company Logo Shop Now
Re: How important is it to use "hy-tran"
bc
02-22-2021 07:14:26
Likely the steering hand pump or the oil gauge. A check of the engine oil will determine that. Engine oil tends to turn black so another indicator. Hytran doesn't have a dye that I am aware of and will look like motor oil when new. Hytran picks up a lot of water and becomes milky with a slimy feel to it. Definitely needed a change when it started to get that way. I and others use the cheap hytran and most of them do meet the ms-12xx standards. Used 303 from orshelns and now get the cheap VP hytran from TSC. There are threads around. Engine probably holds no more than 8 or 9 quarts and hytran probably not more than 21 quarts so if you lost a lot it won't be hard to find what it is.
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
