Timing for a Farmall F-12
Eddie
05-02-2001 20:26:50
I need to know how to time a 1936-37 Farmall F-12. Recently bought one and it is out of time. Please help!!!!! !! You can e-mail me or answer here. Thanks so much.Eddie bigg_ed178@hotmail.com.
MikeH-Tx
05-03-2001 17:14:24
 Re: timing for a Farmall F-12 in reply to Eddie, 05-02-2001 20:26:50
A similar question was asked a couple days ago (3 or 4 pages down now). Go here for the info. It is about an O-12, not an F-12, but both answerers (F14 and me) know the F model much better than the O model anyway.
Brian
05-03-2001 05:45:42
Eddie,
First get the crankshaft in the top dead center position for the #1 cylinder(towards the front). then it's just a matter of putting on the timing gears and matching up the small marks on the face of the gears. If I remember correctly the gears can only go onto their respective shafts one way. So put the crankshaft gear on first the just simply turn the camshaft by hand until the marks line up. Now you didn't say if you had you motor all torn down or why the timing might be off. You get small adjustments as far as the spark goes by the magneto coupler and moving the screws a hole or two at a time. Timing the magneto is a diferent story all together, post back and tells us a little me about your project and there are many people here with a lot more experience then I to answer questions. I have found them to be invaluable.
