Problem: my temperature guage needle needs extreme temperatures and work load to budge.
Well, I asked about this in the past and had a couple responses. I will tell you what I found so far. Sorry if this topic has been covered in excess.
I removed the engine cover and the front radiator cover. I emptied the anti-freeze through the drain at under the front bolster (I think that is what it is called). I removed the clamps at the top radiator hose and slid it up. I found the gap too narrow to wiggle out the thermostat. I felt stuck at that point.
I needed to loosen the lower radiator bolts to rock the radiator forward and out of the way. But, my loader is in the way. So, I lifted the loader up and forward. I was able to remove the nuts and tilt the top of the radiator forward and remove the thermostat. It was the original style thermostat and it is rated at 165 to 195 degrees. The retainer was intact and sitting in the groove.
I put my NOS thermostat and the one I removed from the tractor in a kettle of water and heated it while monitoring it with a thermometer. They both opened roughly at 165 degrees and eventually went fully open by 195 degrees. My problem is likely not the thermostat.
As people said, it is likely because I rarely every load my tractor and it has built in over capacity for heat dissipation.
The parts manual shows two temp range temp gauges, I suppose
The temp gauge could be dis-functional? Or, everything is working fine.
