06 series
CDN 400
01-22-2021 17:48:59
Trying to end an argument here. Was the mcv tellite and engine oil tellite on all 06 series in the big gauge on the dash? I know the 66's had a separate light down by the key.
CDN 400
01-22-2021 20:27:56
 Re: 06 series in reply to CDN 400, 01-22-2021 17:48:59
Thank you to all you guys, I've owned 5 06 series and could not remember and should have known.
pete 23
01-22-2021 18:36:52
All 06 series tractors had the combination engine oil pressure and transmission lube red light in instrument panel on same circuit. Separate sending units, one on engine, one on MCV but all hooked to just one warning light.
The 56 series had separate light, one for each system.
Engine oil light was in the cluster and MCV light was mounted lower down on panel.
d282
01-22-2021 18:33:55
Yes
rustred
01-22-2021 17:54:53
As far as I know. It’s a goofy set up.
