A long story short regarding the Seal on a Farmall M. The mechanic told me he had worked on all types of Farmall tractors for 20 years, especially Farmall M’s. He said the seal was a quick fix. I took the tractor in. However, this mechanic quit before he started work on it.. My tractor sat there for five weeks before I was contacted.
Later two mechanics were assigned to fix my M. The shop owner has two different shops so the tractor was moved to his heavy motor truck shop. At that shop, the labor rate is calculated on the computer from hours to flat rate.
The owner and I agreed to do some research to come up with a fair flat rate price. This is why the flat rate came into play.
In conclusion, they split the tractor and the front portion of it (clutch to radiator and grill) was pulled apart, and it the process the tractor tipped off the forklift and smashed.
The first meeting I had with the owner, he stated the labor hours the mechanics had accumulated seemed very high. (17 hours)
My thoughts are very close to what was quoted by you fellas and that would be 3 to 5 hours.
When I took the tractor into the shop, it was clean of grease, etc. as I had pressure washed it.
Thanks for your help.
