oldfarmall
Hello-
I have a Farmall 300 row crop tractor with the C-169 engine. This past spring when I changed oil, I noticed maybe a cup of green coolant came out first before the oil when I removed the oil pan drain plug. Well, I had other tractors I could use, so I put new oil back in the engine and put the tractor back it the shed until now when I had time to work on it.
I drained the oil this weekend, had some green coolant in oil pan again. I have removed the oil pan and wiped up all oil in the underside of the engine and crankshaft area.
Read that you pressurize the cooling system and wait for the coolant leak to appear. So I did this, pressurized to 5 PSI. Well, my radiator cap leaks bad and had small radiator leak, so that option is out until I can plug the radiator hoses and re-pressurize the system.
Since draining the oil and wiping everything down this weekend, I am seeing green coolant leak into crankshaft area above the camshaft, without pressure in the cooling system, it takes overnight for the coolant to reappear. I wiped off the camshaft 2-3 times now and the coolant seems to be dripping in the same spot above the camshaft and no where else in the underside of the engine. Coolant appears to be dripping from an oil return hole about size of a dime in the block above the camshaft between the 2 lifters for the 2nd cylinder from the rear of engine.
Can anyone give me an idea if this appears to be a cracked head, cracked block, or bad head gasket? Possibly what I should do next? I did do a compression check last summer and noticed nothing odd about the readings between cylinders. Any info is greatly appreciated. Thanks!
-Jesse
-Jesse
