Farmall & IHC Tractors Discussion Forum |
Bosch coil
Author |
[Modern View] |
Hp super c
01-11-2021 16:14:20
Has anyone used a Bosch blue coil on their Farmall? It claims to put out 50,000 volts.
Janicholson
01-11-2021 21:54:45
Re: Bosch coil in reply to Hp super c, 01-11-2021 16:14:20
Coils only putout voltage that fires the plug. 50,000 is lots. 20,000 is more than needed in our world of tractors. If the primary resistence is around 3 to 4 ohms it will not overload the points. If less, it will not be a long lived proposition. Unless there is something very wrong, it does not need voltage it will never reach. Jim
Hp super c
01-12-2021 02:11:38
Re: Bosch coil in reply to Janicholson, 01-11-2021 21:54:45
I checked the specs on a stock coil and it’s 1.5 ohm. Same as the Bosch I found. The reason I’m looking for more spark is I put a 3.25 stepped head piston kit in, 240 head and manifold, and a bigger carb. I’m thinking I can get a little more out of it if I get a hotter coil and open up the plug gap.
Janicholson
01-12-2021 06:44:21
Re: Bosch coil in reply to Hp super c, 01-12-2021 02:11:38
If you are pulling with it fantastic. The plugs are probably firing in a 150 or so compression pressure. maybe a bit more you probably know. Gapping a .025 plug to .035 changes the required voltage. Plugs fire as soon as they are presented with enough voltage to jump the gap, and no more. I spent my first 30 years in the automotive industry. and I have seen engines needing 25,000 volts to run at 7500 rpm in cars, and 15,000 in motor cycles. Looking at diagnostic equipment. So at 7 volts running and charging it would draw about 4.6 amps. if running 14.6 volts charging, it is well into 8 amps without resistor. With resistor of similar ohms, you are back to the 4 amp OK level. A dyno will tell you the answer. Seat of the pants maybe not. If it misses at all when in operation it could help. especially if the original coil had a path to ground before it reaches plug firing voltage. Good luck with it, I like increasing performance until things break. Jim
Hp super c
01-12-2021 10:16:59
Re: Bosch coil in reply to Janicholson, 01-12-2021 06:44:21
The compression ratio on it is somewhere between 8-8.5:1. The stock 240 had 7.3:1 with flat pistons. The step on the new piston is .2” and the piston is a few thousandths taller from the wrist pin, plus the bigger bore. I’m trying to get it over 40 HP to the PTO.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
