I had bought a Farmall 706 diesel several months ago and have time this winter to properly bolt the operators platform down. I don't think any bolts have ever been holding it down since I acquired it. Seems like it always stays in place with all of the cutouts it has to fit into. Anyway it appears that all of the bolts are twisted off at the transmission/rear end/brake castings. My question is how many bolts hold it down and where are they located? I see one hole on each brake housing (have those broken bolts out). I also see what appears to be two broken off bolts 10 inches apart about 8 1/2 inches ahead of the brake housing holes at the front of the top of the transmission cover. Are there two bolts mid way back on the transmission cover? Looks like broken bolts there as well. The on-line parts diagram is not much help. I know there are spacer sleeves that must be used. Thanks.
