Farmall & IHC Tractors Discussion Forum |
Farmall 200 throttle linkage.
Author |
[Modern View] |
Lmack
01-10-2021 14:28:19
I had to replace my manifold and in the process broke the throttle linkage lever down by the water pump. I have a replacement. It looks like the water pump has to come off to replace the lever. Is that correct? Also I am not getting enough RPM's at full throttle. I guess that adjustment is in the governor. Is that correct?
Lmack
01-12-2021 11:32:49
Re: Farmall 200 throttle linkage. in reply to Lmack, 01-10-2021 14:28:19
Thanks. I was not looking forward to removing the water pump.
GENE BENDER
01-11-2021 02:18:42
Just back off the bolt that holds the lever to the shaft and the lever can be removed. After replacing the lever you need to set the linkage going to the carb. That clevis will be frozen to the shaft and removing the rod from the engine you will be able to free it so it turns easy. Hard to do with rod attached to the carb. Get an I@T manual for that tractor it has all the settings and lube info timing the engine and so forth it will be handy to have all the settings and oil,coolant adjustments for the tractor
Charlie M
01-10-2021 14:44:16
I've found it a lot easier to remove the governor than it its to remove the water pump. Make sure you have a gasket for it as the old one may not get saved. Get your linkage fixed and adjusted correctly then see what you have for RPM's.
560Dennis
01-11-2021 08:42:38
Re: Farmall 200 throttle linkage. in reply to Charlie M, 01-10-2021 14:44:16
Good idea to take the governor off , always find something to fix up in there . Broken spring thrust bearing etc.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Talk of the Town: Trailerin a Tractor, Chains or Straps? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: " I bought a trailer and plan to take my CASE VAS to some shows. I don't yet have anything to secure it to the trailer. So which is better to buy and use; the ratchet-type straps or binders and binder chains?
... [Read Article]
Latest Ad:
Carburetors for sale Marvel Schebler models TSX 408 and a TSX 244 B both rebuilt. Asking 250.00 each Then I have a Carter UT 0-652 on base 0-653 24 on neck with 179380 on throttle shaft asking 50.00 for this one.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
