grandpa Love
On our new cub the graphite bearing that works like a throw out bearing is loose and rattles around, way more than it should. It is in the hanger correctly and just pivots back and forth too much. We have taken the round cover off the hand hole in bell housing on 2 of our other cubs to compare. It appeared that the bearing needs to be closer to the clutch fingers. Pedal is already as far that way as it can go. It also appears that the bearing and metal carrier are brand new. Only shiney thing in there!! Is it a simple matter to adjust the clutch fingers closer to the bearing? At this point the clutch is working perfectly. I can rest my foot on the clutch pedal and it moves the bearing just enough where it doesn't bounce around and rattle. With tractor off and looking through the round hole it appears it needs to move 1/4 to 12 inch closer to clutch fingers. Will adjusting the fingers affect how the clutch works?
