anotherbri
Hi everyone. My 1949 era Farmall H magneto ignition is running rough/popping while under load, such as pulling a log or even just going up a not so steep incline. I've had this unit for 22 years and never encountered this problem. It starts right up, no problem. It idles like a purring kitten. Throttle wide open, it runs with no problem and sound normal. Under a slight load, it sputters and pops until it catches up to the load. If I rapidly advance the throttle from idle to high speed, it sputters/pops until it catches up. Runs full throttle fine. At first I thought it was starving for fuel, but now I'm starting to think it might be rich. If I pull the choke on while running wide open, it mimics the same problem as when under load.
I cleaned the bowl, replaced the in-line fuel filter, pulled the line off the carb and cleaned the screen which wasn't really dirty. I blew out the line with compressed air, as well as back into the tank. With the fuel line off and valve open, fuel flows steady from tank. I pulled all 4 plugs and they jump a spark while holding them about 3/16" away from ground. The firing order is correct 1342. The cap had some dirt and I cleaned it out, but noticed the center carbon springy thing fell out. The spring deteriorated. I put on another used, but good cap I had. Also cleaned up the rotor and cap contacts with a dremel wire wheel.
The spark plugs were carboned up. I wire brushed them and used a fine sandpaper between the electrodes and re-gapped them. Also, I pulled the 2-3-4 plug wires and started the engine with just #1 connected at an idle. Then put #2 on and took #1 off and so on for all 4 cylinders. The engine will run on one cylinder no matter which cylinder it is except #4 will run only a couple seconds before stalling. This test was done before I cleaned the plugs. Since #4 would stall, I switched the 3 & 4 plugs. I didn't get chance to see if #4 will run better by itself yet.
The high speed jet on carb is 2-3/4 turns out. Also, 3 turns out makes no difference.
I think my next step is to take the carb apart. I rebuilt the carb about 5 years ago. I've also switched to non-ethanol 89 octane fuel.
I'm open to all thoughts. And I'll be honest, that governor confuses me a little.
Thanks for reading,
Harry
Thanks for reading,
Harry
