oiling Cub fan bearing- i need refreshing
Good evening: I know my 1958 Cub fan hub can be oiled easily, but I don't have the written procedure available right now. Please refresh my memory.
Dennis M. in W. Tenn.
Ya what u need to know ? It has a plug , remove plug fill half full and done,
in a nut shell. I would use gear oil.
Unless you want lots of oil spattering around, try the official procedure, which will set up the oil level below the shaft area.
<img src = "http://farmallcub.com/phpBB2/download/file.php?id=32866&t=1">
The slinger in the fan assy will not pick up the heavy lube and spread it on the shaft. That system has been around for like 80 yrs and still works if the correct oil is used. I have several of the original systems still working just fine so they have had good maintence or they are still doing their job
