Case IH 385 Brake Problem
RNanno
New User
I have a Case IH 385. The right brake pushes to floor. I have changed the master cylinders, checked the steel tube in the drain hose on the reservoir and then changed the 3 o-rings for the brake piston. No fix.
When I go through bleed process and clamp off the reservoir drain hose, fluid runs through bleed valve with no air bubbles. When I push the pedal while bleeding, a surge of fluid comes through. So it seems to have air out and also seems the master cylinder is working since a surge of fluid comes through. However, when I close off the bleed valve the right pedal still goes to the floor.
Any suggestions what to check next?
Thanks.
A surge of fluid when no resistance is provided is different than when under pressure. The piston in the master cylinder may be collapsed and bypassing
when asked to make pressure, not volume. Jim
Hi, this a test an old IH Mechanic used to perform, remove the hydraulic filler plug from behind the seat, with an air supply pressurize the brake line from the master cylinder to the rear axle and listen at
the filler plug for air, this should be good on your 385 as you have replaced the O-rings, next was to disconnect the brake equalizer pipes and plug the fitting on the master cylinder and bleed and test the
brake.
The other problem is the bushing on the brake pedal shaft when it becomes too worn when you press on the right brake the the actuator rod is pushed at an angle into the master cylinder and the hydraulic fluid
leaks past the master cylinder piston.
See link to PA Farms IH Utilities, IIRC they did a youtube video on replacing the brake shaft bushings.
Thanks. I hope that is not it since I put a new master cylinder in. I may cap off the brake line to see if it is in the master cylinder.
Try applying the brake with air: take the line off from the master cylinder at the
axle. If it holds air, then the brake piston is ok and the problem is the master
cylinder or the line from it, but the line would show a leak. It is easy to cut the o
rings at the brake piston at the axle, and I would bet that is the problem. Mark.
RNanno,
Were you able to find the problem? I have the same tractor with the same issue right now. I replaced the master cylinder and checked the reservoir as well. I didnt do any o rings yet but part of me is thinking this still may not work. Did you just have the issue with one brake or both? I was hoping it was going to be an easy fix, was it a difficult job to do the orings?
