Super A dist cap
GregtheDC
I purchased new points, plugs, condensor, coil and distrib. cap from this site, Getting ready to install, but there is a manf. hole in the side of the dist cap, is that normal? have not removed the old one yet
Thanks
G
leave the old condenser in way too many of the new ones fail just let there and you will always have a new on if you ever need a new one those old ones last forever. Last new one failed in the first half day on a tractor ride put the old one back and engine is still running.Only new one i would trust would be an ECHLIN. You should clean the new points with alcahol to remove any coating sometimes found on them
I will give this a try this week, will put the old condenser back in. I didnt do anything to the points so maybe that will help.
