Super A Clutch Repair Pics (Day 2)
Tyler (MD)
04-26-2001 15:41:42
third party image
Made some bracing for the front and rear half. The welder at work cut the two vertical pieces exactly an inch too short on the rear brace. Will fix tomorrow. Thank gosh for prototypes. :-)
Bolted it all together. It seems real sturdy. I'll also use back up bracing just in case of collapse. :-)
Take care,
Tyman
Haas
04-27-2001 05:12:50
 Re: Super A Clutch Repair Pics (Day 2) in reply to Tyler (MD), 04-26-2001 15:41:42
I like the support! Did you build that? I need to split my C to repair a leak at the front of the transmission and need something similar.
Tyler (MD)
04-27-2001 16:46:38
 Re: Re: Super A Clutch Repair Pics (Day 2) in reply to Haas, 04-27-2001 05:12:50
Yep. I made the supports at work. Well...I designed it and helped cut the 1" tubing and another feller welded it. It's strong and sturdy.
Tyman
Keith Seymore
04-27-2001 06:56:11
Very nice! I imagine you'll get a few requests from these guys to borrow it!
I'd like to hear about that spin on filter too when you get a chance. Is that a retrofit kit?
Tyler (MD)
04-27-2001 16:45:05
 Re: Re: Re: Super A Clutch Repair Pics (Day 2) in reply to Keith Seymore , 04-27-2001 06:56:11
Don't know much about the spin filter adapter. It was on there when I bought the tractor. You may be able to get a kit at an IH dealer.
Tyman
RON/PA
04-27-2001 02:40:04
Really like the bracing, looks like a setup to handle the job and make separation alot easier, when you are all done and have a minute, please tell me about your spin on oil filter, as opposed to the canister that I am still using.
Thanx RON/PA
Glenn(WV)
04-26-2001 20:13:31
I really like the bracing! That's pretty slick.
BOB[PA]
04-26-2001 17:09:47
hey tyman looks good i like it.boy i hate to think of puting a wrench on that baby ? nice paint job. well ty you gotta do what you have too.
when you are in there make sure you look at the tube that throw-out bearing rides on. mine is starting to crack at end plus it is loose have to split like you are doing.
best of luck bob[pa]
