Absent Minded Farmer
- Location
- Hey! I'm over here now!
failure to make sense! So, is the tester a fibber or is it the gauge? There are however, no numbers on the gauge, so it might as well be pointing at the floor.
Both readings are with the engine wide open. According to the tach, it's just a hair under 2000 RPM. Is that charging rate a little low? Thought it was supposed to be 14v or 15v. There's still a genny on it if you're wondering.
Mike
Mike
