Thor Wicklund
I have a 806 gasser that has been sitting for a year. Pulled tank and cleaned/rinsed, new fuel bowl and carb cleaned. I have been working on this on and off for a week. It seems to run like in the video most of the time. Today I put in new plugs, wires, cap and rotor and did not see much of a change. Last night I pulled the carb off for the 5th time, cleaned, new float and float adjust, new needle and seat, not much of a change. The video is at idle, if you give it any throttle it will die. I cannot see the sediment bowl in the tank because of the baffle, but seem to have good fuel to the carb. Not much to adjust on the carb, unsure what else to do. Replaced ignition componemts except coil and points. Do I have a fuel problem? or ignition problem? Thanks
