blueridge
- Location
- Crawfordsville In
I Have a 1942 H and on last tractor drive was on a Gravel Road like a Washboard and quite rough and noise started, pretty solid knock, stopped when I pushed in clutch. After while it was not as loud and I released clutch several times and it finally stopped. Drove about 20 miles to home and didn't hear it again until I moved it in my shop today, and there it was again. checked it out. dropped plates in front and behind Hyd. Pump and took out Hyd. Pump and looked at thro-out bearing and shaft. and Coupler and they all seam O.K. I restored tractor in 2010 and has only been used on tractor rides since. I rebuilt coupler then. Bolts are tight and rubbers look good. The front Trans Bearing is a little loose. Seems like knock is in that shaft, you can feel it in the Trans. Case, even under your feet, pulled belt pully housing and gear off and don't see anything out of order. Has anyone had this problem with an H and what is causing it?? Thanks to anyone that can answer this . Gene
