Read thru the manuals that I have for the tractor. My limited t/a experience is only from my IH 560D & this 400. The 560 did pull the bush mower around the barn yard till the Farmall H with belly mower came along. Didn't really use the t/a on the 560.
Didn't notice any issue with the clutch or t/a on the 400. When handle is pulled back tractor slows down & speeds up with it ahead. Don't have a lot of use for the t/a, it grades the driveway & loader work around the yard. Meaning like lifted a dead tree, lift something heavy, etc.
Clutch adjusted is 7/8\" between pedal & housing like book says. It pushes nicely with no grinding of gears. According to the manual, the t/a is out of adjustment. So adjusted it, holy cow it the clutch pedal really hard to push now! Does this mean the t/a is worn out? I brought this tractor used couple years ago & don't know much of its history.
Thanks, Scott.
Thanks, Scott.
