I'm getting ready to pull my hand pump from my 504.
It is leaking under the steering wheel. I replaced the seal under the retaining ring but it still leaks bad. Also the output shaft has slop side to side. I guess I will need to replace the entire unit. Where is the best place to find one. So far the only one I see is on eBay. Very expensive.
Part number 373069r94 thanks
