I pulled the motor to replace the rear main seal. The tractor had been sitting for 20 years so not too surprising. Runs like a top though and I used it since last fall. Rear main started to leak this spring.
Might as well replace several things while I have it out, throwout bearing, pilot bearing, front crank seal, hoses and belts.
Is the fan belt a 7/8 x 49? Napa lists it. Also, what is the length of the gen belt? Its 1/2 but how long? I intend to switch it over to 12 volt so if anyone has done this, what belt did you use?
