Hello guys. Thought I would start a new thread. Took the block to the machine shop today. They will pull the crank and the 2 stuck pistons and see what it will need. He couldn't find any oversized pistons with Reliance and his thinking is that it would need to be bored for dry sleeves with them being bored for standard pistons depending upon how it all check's out. I told him I would check on parts and options. I am not sure why you can't bore it and use standard pistons with oversized rings.
It is a approximate 1966 model 2606 industrial with a c221 sleeveless engine serial number 50541 that I believe came from a 303 combine of unknown year. Any ideas on this is appreciated. Inside the block in 3 places are casted numbers c185, f185, and r185 for every 2 cylinders. While every thing is in the shop, I can paint the rest and I need to replace the high side 12 gpm hydraulic pump with a 17 gpm and may replace the low side depending upon the price. Thanks, Britt
