What parts are you replacing? I thought about buying an F30, but didn't see any source for parts like pistons. Engine is really stuck.
To my knowledge, there aren’t any new sleeves/pistons available for the f/w 30. Need to have them bored and dry sleeved. Then they can be honed to match the piston size.
i actually found my set of new old stock high dome pistons today for a w-30. dam things got rusty from sitting.
All I have ever done on these is replace rubber o rings,hone the sleeves and install new rings,Never had a problem.Rings and a valve job and they will start the first crank,with a hot mag
