Hey all,
I've got an International 340 Utility tractor that I've been trying to get up and running correctly. It is the first tractor I've owned, but I do have some mechanical/engine knowledge from my years working on cars.
I was hoping that I might get some pointers as to what I should look into on this tractor to get it running right.
It starts up great and even moves around in 1st and 2nd gear just fine, but when it's under load of any sort (even simply going uphill on gentle grades), it just runs out of power and stalls out.
[list:c4044d9eef]
[*:c4044d9eef] I've rebuilt the carb, checked that it was clean and that the needle and floats are working correctly.
[*:c4044d9eef] I've checked the fuel lines for flow issues, but it's also doing great.
[*:c4044d9eef] Governor seems to be working fine, but even manually moving it to maximum power, it doesn't have much to give.
[*:c4044d9eef] I have bought new spark plugs Champion 515's. - the ones in the engine came with it when I got the tractor were NGK's. Number 2 plug looks brand new, but 1, 3, and 4 plugs are carbon fouled. I haven't put them in yet, but plan to do so soon.[/list:u:c4044d9eef]
What else can I check on that would be related to a loss of power under load issue?
Thanks,
- Snowfall
[list:c4044d9eef]
Thanks,
- Snowfall
