Company Logo Shop Now
Farmall M radiator again..
JASFarms
09-16-2020 13:32:25
I asked the other day about an M that was running a bit warm. I took the radiator out and the radiator shop said it was plugged internally and they said the core is too weak to rod out. So I got a new radiator from Shoup....it wasn’t til I got home that I realized the one Shoup sold me is a 3 row core while the old radiator has 4 rows thick. Looks like it’d be $600 plus shipping to get me a 4 row. Is it really necessary? All the tractor does is run an 8” auger on one of my farms. Will the thinner radiator work or should I stick with one like I had. Thanks.
md_650d
09-17-2020 09:06:58
 Re: Farmall M radiator again.. in reply to JASFarms, 09-16-2020 13:32:25
Just look around for a good m radiator you will be happy with a good original one. New ones are junk I may have a good used one I have to look
rustred
09-17-2020 18:23:19
 Re: Farmall M radiator again.. in reply to md_650d, 09-17-2020 09:06:58
he has one bought already so why screw around with another plugged one.
John M
09-17-2020 02:46:05
The 3 row rad will be fine, but you may have alignment issues with the shroud and grill. Took 3 tried for Shoup to get me on close enough to fit. (This is assuming they still use to same supplier.)
MtMan
09-16-2020 19:11:04
I have an older Farmall that doesn't have a water pump. My radiator started leaking and that's when I found out most of the radiator shops in our area are out of business. I was going to get a new radiator but was told not to because the new ones didn't have enough capacity for the older engines without a water pump. I finally found a fellow that would repair mine and I'm well pleased and saved a bunch of dollars.
rustred
09-16-2020 17:53:57
you will be just fine. actually be better as it will warm up faster. sure not going to over heat running an auger. your tractor was running with a plugged rad before.
Kalven
09-16-2020 17:28:05
Before I found a used radiator for Super MTA I was looking at aluminum radiator for it. It was less money and the aftermarket copper ones I have seen don't fit right and the brackets come loose at the solder joints.The only thing was the aluminum one didn't have a drain in the bottom.My tractor ran at the edge of the red with the aftermarket junk that started leaking in the tubes,4 core original that I found it barely gets off the cold mark.
old weldor
09-16-2020 15:35:17
There are a lot of people parting M tractors out. You might be able to find a good used one.
Jhncp
09-16-2020 15:06:39
I needed a radiator for my M because it started spring pin hole leaks like crazy. After leaving it sit 5 years I finally just bought another M for parts for $350 and got a good radiator and a bunch of other parts I needed and have parts to sell. Much better than buying a $600 radiator.
Copyright © 1997-2020 Yesterday's Tractor Co.
