Company Logo Shop Now
Farmall B steering repair
jCarroll
09-15-2020 14:48:42
Our B had lots of slop in the steering - the steering wheel could be turned 70 degrees without moving the front wheels.
Although there is noticeable wear in the steering shaft U-joint, the real culprit was the ball bearing in front of the worm. That bearing takes the axial load in both directions. The old bearing was worn such that the inner race could be moved "back and forth" about 1/16". The new bearing is "tight".
Now I have only 20 degrees slop in turning the steering wheel, and no road gear shimmy.
I will post the bearing number if anybody wants it.
gene bender
09-17-2020 05:46:59
 Re: Farmall B steering repair in reply to jCarroll, 09-15-2020 14:48:42
Put two clamps on the u-joint tight then take a torch and get them red let them cool over nite or so that will take out that slop ive have done that several times to them grease em and go for it
J.Wondergem
09-15-2020 16:15:52
My steering U joint was shot on my BN. I took the shaft measurements ,went on ebay and found a race car steering joint with the right size for the shaft and welded it on. It'll last the rest of my life.
Ken Hansen
09-15-2020 16:12:52
Yes please do the way CaseIH has destroyed the online parts books every source of information like this is very important.
I wish Case IH could understand that no one who is trying to restore and keep these old tractors running is likely to be in the market for a 2020 tractor. So why do everything they can to hide the old information?
jCarroll
09-16-2020 06:17:36
 Re: Farmall B steering repair in reply to Ken Hansen, 09-15-2020 16:12:52
NSK brand. Bearing number 6205VVC3.
Copyright © 1997-2020 Yesterday's Tractor Co.
