Retiredbusdriver
New User
I have a smaller cub lo boy with 12v battery ignition with distributor and coil.
What I thought was bad connections turned into something else. I can start the tractor by hotwiring directly from the battery to the coil. Tractor stays running after i remove the wire. Will not start any other way. No voltage to the key switch. I checked both the wire coming from the regulator and going to the coil with ohm metrr. Both fine. Im at a loss why i have no voltage to my 2 position key. I need some help.
