Company Logo Shop Now
460 diesel no fuel to injector lines
Jhncp
09-14-2020 11:08:53
The tractor has been sitting about 10 years. Fuel is to pump but nothing coming out of return line or injector lines. The head is off so it spins over fast and easy. The fuel filters and fuel that was in it looked clean and good.
pete 23
09-14-2020 14:01:00
 Re: 460 diesel no fuel to injector lines in reply to Jhncp, 09-14-2020 11:08:53
Most likely stuck pumping plungers but could be stuck metering valve. I personally would put my gauge on and check for primary fuel pressure and go from there. You can easily take top off pump and see if throttle moves the metering valve and if it doesn't a finger gently push it up and down and back and forth.
No way to see pumping plungers sooooo, a few raps on the solid portion of pump with a soft hammer might just jar them loose if you are really lucky. Other wise, it is tear down time.
Jhncp
09-15-2020 15:37:47
 Re: 460 diesel no fuel to injector lines in reply to pete 23, 09-14-2020 14:01:00
I spent the entire day working on it and wasn't very optimistic but after the 2nd attempt putting it back on it works. Most likely was the 2 main pumping plungers, I had to hit them pretty hard with punch to get them out.
Jhncp
09-14-2020 15:05:16
I took the top cover off and wiggled stuff and have been tapping lightly on pump but still dead. Looks like I I'll have to pull it off tmrw. I just met the ups man and got my new head gasket but sucks i mizle get the injector pump working first while it's easy cranking.
Jhncp
09-14-2020 13:49:17
I now have fuel being pump thru return line but still nothing from injector lines.
Dieseltech
09-14-2020 13:48:23
Injection pump probably has several stuck internal parts from setting that long with stale fuel. I repair several each month in that shape..
Copyright © 1997-2020 Yesterday's Tractor Co.
