This message is a reply to an archived post by D Slater on February 26, 2015 at 11:34:52.
The original subject was "Re: Farmall 300 independent pto, broken drive gears, help".
I have a 300 also but my front bolt and washer fell out of the front pto shaft. I have the tractor split by the flywheel area. Can I drive the pto shaft back enough to replace the big gear with broken teeth without removing that section of transmission from the rear half?
