Hi Guys
Newbie here Ive got a head scratcher I just picked up an International 606 gas about a week ago and it started and ran fine loaded on the trailer and and when I got ready to unload it a couple of days later the starter wouldnt turn the engine over the starter drive was engaging the flywheel but acted like the engine was stuck I removed starter thinking the starter drive was binding up but when tested it seemed fine.I ended up putting a new battery in it and finally got it to start and backed it off the trailer.I used the tractor a bit and it runs great and is full of oil but did have several hydraulic leaks so I shut it off and fixed most of the leaks and let it set a couple of days and now it acts like it is locked up again.Heres what I have done so far new battery,new starter,pulled spark plugs,jacked up rear end put it in gear turned wheels but the flywheel is not moving Itried a pry bar on the flywheel but cant get engine to move even with plugs out.and this is the second time this has happened it does have the T/A and it does work I am stumped at this time and could use suggestions it does have a 2001 IH loader on it.Sorry for the long post could the hydraulics be locked some how?
