1957 350 for mowing? And looking good.
Would it work for use with a finishing mower? Yes it would but, it's awful heavy. It might leave tire tracks in the ground. I mow with an 8N ford and if the ground isn't dry and hard, you can see and feel tire imprints in the ground. Don't mow in the same tracks every time. Nice looking tractor. get a 3point conversion kit. I've had a 6' King Cutter for 11 years. Does and excellent job.
Looks just like my 350 except mine isn't as pretty. Good tractors but like was said they would be on the heavy side for finish mowing on nice grass - 5500 lbs or more. I like the wide front on mine but it does make for wider turns. For mowing I'd prefer the utility model of the 350 which would be shorter and more maneuverable. I would also say that they're asking way too much for this one - I wouldn't pay more than about $4500 and then only if everything on it works.
Going to develop good size arms and shoulders mowing with Wide Front . Good for kids going out for wrestling and football. Oh also right leg for brake steering . Nice 350 good luck with it.
Does it have power steering ? Ad did not say .
They dont steer hard. I have a 300 U here. Doesnt steer 'hard' at all.True it's not power steering,but not bad at all. I could drive it all day.My wife drives it too..Now,put a loader on and it's a different story.
I put a 3 pt hitch on my 140's and mow with a 6' woods finish mower. It works great. That 350 could pull a much bigger mower easily. Nice looking tractor but I wouldn't go over $4,500 either. OK, maybe $5,000. Good luck and thanks for the pic.
The price is really high - everything better work like new (including the TA) for that price.
I have the exact same tractor - including the same wide front. Works great as a hay mowing tractor - I mow with both 7 and 9 foot balanced head mowers. To use as a finish mower you might find the height gets in the way of getting under trees. Not that heavy of a tractor - basically a grown up H with a lot more options. Very fuel efficient compared to other row crop sized tractors that can do the same.
