coupling parts on clutch shaft on farmall H?
Does anyone know where you can get the new rubbers and shoulder bolts on the spider coupling in front of Transmission on a Farmall H ? mine are very loose? This site don't have them nor Steiner. any ideas?
Thanks Gene
For stuff like that i go to I-H they will have them to many tractors were made using those for them not to have that part
I almost bet if you called the YT parts dept. they could get them for you. Steiner no. IHS4664 for the bolt and 6161H for the rubber washers. I know IH has quality parts but you are probably not looking to pay $88 per bolt, see link.
IH clutch bolt
Go to ebay, they usually list the coupler with bolts. Pretty economical too. I found spare rubber washers someplace, I forget where. The bolts used to be $45 at the dealers 8 - 10 years ago, I went on ebay and stocked up.
There were two sets in the United States two years ago, one in in Ohio and one in South Dakota, I bought the one from S.D. They are expensive,but a machinist would charge you more, with the set up time!
To find the IH numbers I use a site called avspare to see all the part numbers like the IH site "USED TO" show. Just do a search; type in avspare followed by the tractor you are looking for Farmall H. At this point I have found it works with almost any IH tractor. The search results will show several of the individual parts sections but once you open one there is some small blue print near the top. If you click on the "Description" for your tractor (number 4 in this case) that will open the choices for all the sections for your tractor so you can choose the right one. In this case in the link part No. 30 is the bolt. I just google that part number and got to the Steiner results that way. I have not tried to purchase parts through avspare, when you go to the cart on their site it says "send a price request" and you have to provide an email for that.
Parts diagram
Hi Gene, the part number for the rubber washer is 7579T and this part was first used on the Titan tractors. IH also used the same part on the clutch shaft of the UK built B250 tractors. MJ.
I have a very good complete set of 4 bolts 8 rubber washers 8 retainers, and collar for $25 bucks shipped if you like.
