redbull
My 1086 cab solenoid has 4 wires, 2 big wires and 2 small wires, I have a new one but it only has 3 post, 2 big ones and 1 small one, what do I do with the other small wire. Thanks
With those 4-wire cab relays typically one terminal is jumpered to chassis ground. With newer replacement relays one side of the the coil is internally connected to the relay's mounting tab. If your leftover wire grounds to the chassis it is NOT needed ASSUMING the solenoid mounting tab is making good contact to chassis ground.
