Old and the 856
Ordered a 200PSI pressure gauge so I can test the pressure at the idiot light sensor so it will be a few days before I know more other then maybe checking the condition of the brake disks
you said it did not have that sensor and it was TA delete, and if you only using one guage get a 300 psi one at the least, that way u can do the pump checking with it. the pump will peg 200 lb guage. as you need over 200 psi on a good pump.
No , you want a 600 Psi gauge , Gauges needed for working and testing are a 100 Psi - a 600 Psi and a 5000 Psi gauge . Checking at the sender ya can get away with a 100 PSI gauge as that pressure SHOULD BE around 20-25 TOPS , on the bottom lower right plug here you want a 600 to test lock up and if your going for pump out put that is where ya need the 5000 , always go double the max pressure same as the hose you use . Last thing you want to happen is a gauge explode in your hand or a hose rupture .
yes correct , i was just trying to save him from getting 2 gauges and the gauge rant price going on.
Yes it does not have a TA but it has the idiot light sensor but it does not work so I have ordered a gauge so I can test the pressure where the sensor is. Lot of difference in a TA or in this case lack of TA and a sensor
So your saying there are 2 places to check pressure right??
#1 where the idiot light sensor is and I can use the 200PSI gauge there and then down lower on the same side and need a 600PSI or higher. I do have a 3000PSI gauge I use to test hyd output on tractors
yes , i have them hooked up in my pictures. the bottom u need a #8 orb fitting to # 6 jic male. the top sensor is 1/8" pipe thread to what ever type hose u have. mine are #6 jic. actually vet said there is three places to check but we do not have a spool to install to do the third check. read what he told me as all info is there. only thing with using a high psi guage on low pressure is its not as accurate when you looking at 2 lbs of psi drop.
If the sensor is only going to have 25-200 PSI on it. You could connect it to your air compressor and a battery to check if the sensor is working. With the base hooked to a ground wire and the sender wire hooked to pos. With air pressure it should read at least if it is good or not. Would be the same as an oil set up without the mixing you would have if you hooked it in an oil galley. It would also tell you if it works that you have no pressure to the sender you now have.
i dont think u know what you have to be honest about it. the vet explained to you the differences. you said it dont have a TA, now you say it does have a TA. u sure dont grasp thinks to good is all i got to say. u are in over your head as vet said.
YOUR the one who doesn't have a clue. IT DOSE NOT HAVE A TA I have siad it many times NO TA
Show us a picture you talk about this what time you said it had a TA next time you said it don’t have a TA send us a picture and we will tell you no excuse that you always said you do not know how to do it you asked us all the time about stupid Questions just send us a picture or quit asking these damn questions
I HAVE NEVER SAID IT HAD A TA AND i DO NOT KNOW HOW ANY OF YOU CAN SAY I SAID IT DID THIS IF GETTING FLAT OUT STUPID ON YOUR PART NOT MINE
IT DOES NOT HAVE A TA AND I HAVE SAID THIS MANY TIMES STUPID PERSON IF YOU CANNOT HELP DON'T ANSWER ME
Show pictures and you only need a 60 psi gauge to check lube pressure and a 300 psi gauge for main mcv pressure
Yes that might work but why not be sure and install a gauge to know for sure what you have for PSI
I'll tell you what you send me a camera that will work with this windows 10 system and I'll do that but the camera I have now will not work with it and NO I will not spend the $$$ to buy a new one. IT DOES NOT HAVE A TA AND i HAVE SAID THAT MANY TIMES
HOW MANY TIMES DO I HAVE TO SAY I CANNOT DO picture FOR YOU TO UNDERSTAND MY OLD CAMERA AND THE WINDOWS 10 WILL NOT TALK TO EACH OTHER. I HAVE SAID THIS SO MANY TIMES I HAVE LOST COUNT EITHER HELP ME OR LEAVE ME ALONE
