This is a 24V diesel i am a IHC man my friend has a 4010 that is not charging I was over and looked at it I thought I would grd. the Field terminal on gen and see if that made a difference.( Do that on the IH,s) Well the F terminal sparked with tractor not running. It seems to be energized all the time. ON a IH I would suspect the C/O contact on the VR is not opening. There is a Arm terminal right below the F terminal and on the bottom of gen another terminal with wire I could not make out what that one was. any help on this would be appreciated I was looking for a way to see if it was the gen. or vr. I posted on the JD forum got good replies just know there are a lot of smart folks here also
Thanks probably the best advice I got was to leave it alone if you do not understand it can do much damage.
